Analog Inputs and Relay Outputs
Eos Family consoles can accept analog input through a variety of interfaces. 0-10VDC inputs are received through Response gateways. Contact closures can be received through the built-in remote trigger port on the console (when available) and through Response gateways.
Response gateways can be set up via the Concert software available in the shell. For more information, please refer to the Response Gateway Setup Guides. Configuration of your console’s local ports, including the pin-out of the connector, is available in Setup > System > Show Control.
Analog inputs are programmed through the show control display, where each analog event in the event list consists of a port address and an action. Each event list source references a specific Group ID, which needs to match the ACN Group ID of the I/O Gateway or the Group ID of the built-in remote trigger port, and the events themselves are assigned addresses for the individual addresses or inputs within the gateway.
To enable the analog event list, the external time option must be enabled. This enables or disables function for the entire event list. There is also a global enable for all analog inputs found in Setup > System > Show Control > Contacts > {Analog Inputs}.
