Submaster Triggers
Triggers can be used to tie actions such as macros, show control, or snapshots to submaster playback.
{Execute}
When used after selecting a sub via the command line, {Execute} will open a trigger display in the CIA.
The table on the right lists all triggers associated with the selected sub, along with their reference labels. The delete icon will remove the trigger on that line. Buttons for common trigger targets are available on the left, or can be used via the softkeys below.
{Cue}
Enter a cue or cue list to be executed when the sub is played back.
{String}
Enter an RS232, UDP, or ACN string to be sent when the sub is played back. See Sending String Commands.
{Macro}
Run one or more specified Macros when the sub is played back. Each macro must be entered separately as an individual trigger.
{Relay}
{On} and {Off}
{Snapshot}
Recall a specified snapshot when the sub is played back. See Snapshots.
{MIDI Raw}
Execute an entered MIDI Raw string when the sub is played back. See Sending MIDI Raw with Cues or Submasters.
Syntax
A variety of command line syntax is available when working with triggers:
Action Syntax Example Notes
Add the first trigger of a target type. [Sub] [#] {Execute} {Target} [#] [Enter]
Replace existing triggers of a target type with the one specified. Confirmation required.
Add the first or additional triggers of a target type. [Sub] [#] {Execute} [+] {Target} [#] [Enter]
Remove the specified trigger. [Sub] [#] {Execute} [-] {Target} [#] [Enter]
Remove all triggers of the specified target type. [Sub] [#] {Execute} {Target} [Enter] Confirmation required.
[Sub] [#] {Execute} [-] {Target} [Enter]
Remove all triggers. [Sub] [#] {Execute} [Enter] Confirmation required.
