Loading Faders
Note: Consoles a single cue list cannot map cues to faders.
Faders can also be loaded with cues, presets, or palettes. You can convert an empty fader to a submaster without configuring it in fader configuration display. Any fader can be configured and loaded with a submaster if the fader is not configured, the fader is configured as a playback but has no cue list loaded to it, or the fader is configured as a submaster, but that submaster is empty.
Regardless of the fader configuration, if the above conditions are met, the fader can be loaded with the submaster or target specified on the command line.
If data already occupies the fader, that fader must be unloaded before another target can be loaded. See Releasing Content From a Submaster
- [Sub] [5] [Load] - loads submaster 5 to the fader associated with the load button.
- [Int Palette] [1] [Load] - loads intensity palette 1 to the fader associated with the chosen load button.
- [Cue] [5] [Load] - loads cue 5 to the fader associated with the chosen load button.
