Go To Cue 0
Note: [Go To Cue 0] is used in the examples below. Ion Classic users will need to use [Fader Control] {Go To Cue 0}.
You can use [Go To Cue 0], located with the playback controls, in conjunction with a fader load button to send a specific cue list to cue 0. This action does not use the command line. Simply press [Go To Cue 0] & [Load] for the desired fader.
On Element 2 and Element Classic, you can use the [Go To Cue] [0] [Enter] command to send the cue list to cue 0. This drives all cue intensities to zero, while leaving non-intensity parameters as currently set but no longer under cue control.
See Go To Cue 0.
