Clearing Filters
Applying filters is a toggle state. To clear any filter, simply repeat the application process described above. When pressed again, any applied filter will be removed.
To clear all filters at once:
  1. Press and hold {Filter}. The parameter buttons change to display filter selection. {Clear Filters} appears in the upper left corner of the parameter buttons.
  2. Press {Clear Filters}. Any applied filters will be removed and the highlights will turn off.
  3. Release {Filter}. The buttons return to their normal appearance. All parameters are now available to record functions.
