Address at Level
Note: [Address/Patch] is used in the examples below. Ion Classic users will need to use {Address}, and Element Classic users [Dimmer/Address].
The [Address/Patch] key in Live is used to send level information directly to an output address.
  • [Address/Patch] [5] [Full] [Enter] - sets output address 5 to full. It will return to its previous level once the command line changes.
  • [Address/Patch] [2] [/] [1] [At] [/] [2][3][0] [Enter] - sets universe 2, address 1 at DMX value 230.
With [Address/Patch] on the command line, you can use the level wheel to adjust the level.
After using the [Address/Patch] command, [Next] and [Last] may be used to increment the address number and set it to the same level.
Addresses return to their previous level once the command line is cleared, or [Next] / [Last] is used to increment to the next address.
Note: This feature is useful when you want to perform an address or dimmer check.
