Fan
Note: [Fan] is used in the examples below. Ion Classic and Element Classic users will need to use {Fan}.
When [Fan] is pressed after a channel selection, the softkeys will repaint to the following fan styles:
  • {Center} - The middle channel in the order is set as the start and will remain unchanged, and the first and last channels will change in different directions. The level wheel will decrease the lower number channels and increase the higher number channels.
  • {Reverse} - The selected channel order is reversed before applying the fan.
  • {Mirror Out} - The middle channel in the selected order is used as the starting channel and the first and last channels in the order are the end channels.
    • [1] [Thru] [1][0] [At] [1][0] [Thru] [3][0] [Fan] {Mirror Out} [Enter] - sets channel 1 to 30%, 2 to 20%, 3 to 10%, 4 to 20%, and 5 to 30%.
  • {Repeat} - The number of channels that are fanned before the pattern is repeated.
    • [1] [Thru] [1][2] [At] [5][0] [Thru] [7][0] [Fan] {Repeat} [3] [Enter] - sets channels 1,4,7, and 10 at 50%, 2,5,8, and 11 at 60%, and 3,6,9, and 12 at 70%.
  • {Cluster} - The channels are put into collections, which contains channels with all of the same value.
    • [1] [Thru] [1][2] [At] [5][0] [Thru] [8][0] [Fan] {Cluster} [4] [Enter] - sets channels 1 through 3 at 50%, 4 through 6 at 60%, 7 through 9 at 70%, 10 through 12 at 80%.
  • {Random} - The selected channels are put in a random order before fan is applied.
