Local Output
Note: Changes to these settings may require a restart. When required, a warning message will display.
The table displays all connected device names and their port, address, RDM, doubling, and speed information. The following settings can be edited by selecting a cell:
- Address - sets the starting address for the port.
- RDM - enables RDM on the port.
- Doubled - enables dimmer doubling on the port.
- Speed - choose a port speed from maximum, fast, medium, or slow. The speed may need to be adjusted for certain devices. Defaults to Maximum.
{Output In Client Mode}
When enabled, all client consoles will calculate and output DMX levels through their local DMX ports, including DMX ports provided by Gadget and programming wing devices. Defaults to disabled.
This option is not available when Setup > System > Processors > {Exceed 75k Output} is enabled.
Dim. Dbl. Offset
See Dim. Dbl. Offset.
