Local Output
Note: Changes to these settings may require a restart. When required, a warning message will display.
The table displays all connected device names and their port, address, RDM, doubling, and speed information. The following settings can be edited by selecting a cell:
- Address - sets the starting address for the port.
- RDM - enables RDM on the port.
- Doubled - enables dimmer doubling on the port.
- Speed - choose a port speed from maximum, fast, medium, or slow. The speed may need to be adjusted for certain devices. Defaults to Maximum.
{Output In Client Mode}
When enabled, all client consoles will calculate and output DMX levels through their local DMX ports, including DMX ports provided by Gadget / Gadget II / Programming Wing. Defaults to disabled.
Dim. Dbl. Offset
See Dim. Dbl. Offset.
