Face Panel
Input Devices
{Swap Pan/Tilt}
Trackball settings to swap the pan and tilt parameters. Defaults to disabled.
{Reverse Pan}
Reverses the range of the pan parameter. Defaults to disabled.
{Reverse Tilt}
Reverses the range of the tilt parameter. Defaults to disabled.
{Spacebar [Go]}
Allows you to enable the spacebar on an external keyboard as the hotkey for [Go]. Defaults to enabled.
{Use Shift as Eos Shift}
Allows the SHIFT key on an alphanumeric keyboard to be used as the console's [Shift] key. The Z key on an alphanumeric keyboard will function as the [Shift] key. Defaults to enabled.
{Protect Wheels in Blind}
Requires you to select a category to use with encoder wheels when you enter Blind. Enabled by default.
{Hide Mouse}
When enabled, if the mouse is left idle for 10 seconds, the cursor will go away. Once the mouse is used again, the cursor will return. Defaults to disabled.
Delay
Sets the auto repeat delay for keystroke input from an external device.
Speed
Sets the external device keystroke speed from an external device.
Sounds
Disabled by default. When enabled, allows you to adjust the volume level of the following system alert sounds:
  • Error
  • Advisory
  • Click
  • Cue Alert 5s Warning
All sounds default to 0.
Haptics
Note: This option is only applicable to Eos Apex consoles.
Allows you to enable or disable haptic feedback.
