Add or Edit Keypad Actions
Keypad actions are assigned in the Action Editor.
Note: When the Show Cancel property is enabled "Yes", the Action Editor will automatically populate with an unassigned "Cancel" action.
Add/Edit Keypad Actions
  1. Select the keypad from the Page workspace or the Object Browser.
    Note: When "Show Cancel" is enabled in keypad properties, the Action Editor automatically displays "Cancel" in the action editor list. Add a keypad action to the Cancel action list, just the same as you would any other actions.
  2. In the "Action Editor", click the [Add Action List ] button. The new action list displays with "Unnamed 1" as the default name and "Passcode 1" as the default passcode selection for the action.
  3. Rename the action list if desired by deleting "Unnamed 1" and retyping the new name.
  4. Select a different passcode for the action if desired by clicking to select the Passcode drop down list and selecting from the desired passcode from five available in the list.
  5. Add an action. Click the [Add Action] button, then scroll to select the desired action from the list. See Button and Keypad Action Types for details of each available action. The selected action displays in the editor.
  6. Depending on the action selected, additional options may display in the editor. Some actions require specification of a transition property. Reference Transitions for details.
    Note: Multiple steps can be created for a single action and will be executed in the order they appear in the list. Once created the actions can be reordered (See Reorder and Delete Actions).
