Plug-and-play power at your fingertips
Available in both R12 rack and W1 wall-mount options,
F-Drive is completely customizable for your output needs. R12 can drive up to 48 individually controllable Navis 100 luminaires, while W1 provides power and data support for up to four Navis 100 luminaires.
F-Drive R12 features swappable, mix-and-match output cards, including:
- CC 150 – Four channels of constant current outputs with variable drive current configuration between 200 and 700 mA, allowing 150W total power per card
- CV 150 – Four channels of 24 VDC constant voltage outputs, allowing 150W total power per card
- FTW 150 – Four channels of 450 mA constant current outputs optimized for use with Navis 100 Fade to Warm fixtures
- Chroma 100 – Provides 48 VDC and data for up to four Navis 100 RGBW luminaires
- ArcLamp 150 – Provides power and control for up to 32
ETC ArcLamp luminaires across four channels
