WYSE 50 Terminal Settings for Response Products
Enter setup mode by holding down the [SHIFT] key and pressing the [SETUP] key at the same time.
Settings must be as follows in order for the terminal to work correctly:
The settings in BOLD are the settings that need to be changed from factory defaults
Response Network Controller
Page 1  HANDSHAKE = XONXOFF SCREEN = 80  CURSOR = BLOCK  BLINK? = ON  MODE = FDX
Page 2  DATA BIT = 8  STOP BITS = 1  PARITY BIT = NONE  MODEM PORT BAUD RATE = 38400
Page 3  BLK END = US/CR  AUTO NL = ON  CR = CR  AUTO SCRL = ON  AUX BAUD R = 9600
Page 4  SCRL = JUMP  STATUS = ON  S.SAVER = OFF  PROT = DIM  TEST = OFF
Page 5  KEYS? = US/UK  RET/ENTER = CR/CR  COMPATIBLE MODE = WY50    ENHANCE = OFF
2212
Page 2  DATA BIT = 8  STOP BITS = 1  PARITY BIT = EVEN  MODEM PORT BAUD RATE = 19200
Use the [ARROW] keys to move the highlight bar through all the parameters.
Press the [SPACE BAR] to toggle through the possible settings for each parameter until the correct one displays.
When you are done, press [SHIFT]+[SETUP] again to return to normal mode. Press [Y] to save changes.
Do not press [STARTOVER] or [ESC] while in setup. This returns all settings to their factory defaults.
