  • Will Emphasis Auto-Recover Files On a Quit or After a Crash?
    Question
    Will Emphasis automatically reload the last thing I was working on if I quit or it crashes?
    Answer
    This should happen by default; however, if it is not reloading the last show, check this:
    Go to the Emphasis Mode
    Select Options from the bar that contains File, Edit, Libriary, etc.
    Select Application Options
    Go to the File Options Tab
    Check Reload last Document on Startup in the Document Loading Box
    Also Check Auto Recover in the Auto Save Box
    Select how long you would like to have between Auto Saves. If you wish to keep back up files permanently on the hard drive Check Keep Back Up Files.
