SmartFade SmartSoft Compatibility
What is SmartSoft?
SmartSoft is an online and offline viewer and editor for SmartFade and SmartFade ML Consoles. When used on its own, it allows you to simulate any of the SmartFade Consoles, which allows for creation, editing, and saving of shows. When used connected to a console, SmartSoft provides live views into the stored data and offers facilities to add text labels for show items and see positions of fader levels to simplify level matching and ensure seamless operation.
The latest version of SmartSoft for PCs is available to download here: http://www.etcconnect.com/Products/Consoles/Smart-Family/SmartSoft/Software.aspx
Can my computer run SmartSoft?
The latest version of SmartSoft is compatible with PCs running Microsoft® Windows XP, Windows Vista, or Windows 7 (32 or 64 bit), as well as Apple Macintosh® OS X systems versions 10.4 thru 10.10 (Yosemite). Mac computers running newer software such as El Capitan or Sierra can only run SmartSoft in the offline mode.
SmartSoft requires a minimum 1280x1024 video display resolution. Please see the chart below for compatibility with older versions of software.
Operating System Compatibility:
SmartSoft | Windows 32 bit | Windows 64 bit | OS X 10.4-10.10 | OSX 10.11 and Higher |
1.0.0 | XP or Vista | Offline only | 10.3.9 or higher
Offline only | Offline only |
2.0.0 | XP or Vista | Offline only | Yes | Offline only |
2.0.1 | XP or Vista | Offline only | Yes
| Offline only |
2.0.2 | XP, Vista, or 7 | Offline only | Yes
| Offline only |
3.0.0 | XP, Vista, or 7 | Yes | Yes
| Offline only |
3.0.1 | XP, Vista, or 7 | Yes | Yes
| Offline only |
3.0.2 | XP, Vista, or 7 | Yes | Yes
| Offline only |
Drivers
You may need to install particular drivers on a PC running Windows in order to ensure communications between the computer and SmartFade family console. Please check the release notes and/or operations manual for the particular version of SmartSoft for instructions.
Version Compatibility:
SmartSoft | SmartFade | SmartFadeML |
1.0.0 | n/a | 2.0.0 |
2.0.0 | 2.0.0 | 2.1.0 |
2.0.1 | 2.0.1 | 2.1.1 |
2.0.2 | 2.0.2 | 2.1.2 |
3.0.0 | 3.0.0 | 3.0.0 |
3.0.1 | 3.0.1 | 3.0.1 |
3.0.2 | 3.0.2 | 3.0.2 |
