  • SmartBar  and SmartModule Repairs
    This document suggests some common causes for problems seen in SmartBar and SmartModule units.
    Problems Cure
    No DMX Input
    DMX Drivers are bad
    No Dimmer Output
    Triac is bad
    Will not boot fully
    Make sure TRIAC CONTROL PCB (7580B5428) is plugged into CPU PCB completely
    Display showing OVERTEMP errors constantly
    Make sure TRIAC CONTROL PCB (7580B5428) is plugged into CPU PCB completely.
     Notes:
    • Please be careful when wiring the 3 phase connector. The Z (Phase 3) on some connectors can easily be mistaken for N (neutral).
