  • Setting a Custom IP Address on an Obsession II Processor-Public
    Obsession Facepanels can be configured through their internal software, but changing the processor unit requires a bit more work. To set the IP address on the processor, go to DOS and go into the ETC directory. Type:
    edit config.dat
    and press enter. If the following lines are there, change them to your appropriate values, if not, add them and set them to your values:
    ip_address=x.x.x.x
    gateway=x.x.x.x
    subnet_mask=x.x.x.x
    Remember that an Obsession II network prefers the gateway address be set to match the IP address in an unrouted network.
