  • Response 2212
    The Response 2212 was a protocol converter that allowed you to connect equipment from different manufacturers by converting supported digital or AMX192 protocols to any of a number of other protocols.
     Response 2212
    The 2212 supports protocols including:
    • Avab
    • DMX-512
    • CD80/AMX-192
    • Colortran
    • LMI (Micro II)
    • K96
    The 2212 also features a RS232 connection on a 25 pin D connector for monitoring and configuration. Connection is made in a similar way to the Response Network Controller using a Wyse terminal or terminal emulator.
