Programming Key Shortcuts
There are several 2 key button presses that are shortcuts to navigating the console.
These key combinations are also found in the Online Help system on the console by pressing the [?] key.
The following list is commonly used key combination shortcuts.​
Note-Icon.png Note: The plus (+) symbol is used to denote the need to press and hold the first key, then press the second key while still holding the first​.
LOCK A TAB:
[Park]+[Tab]
EDIT A MASTER:
[Modify]+[Master button] (opens the master editor)
RELEASE CHANNELS:
[C/Alt]+[Ch]
​CLOSE ALL UNLOCKED TABS:
[C/Alt]+[Tab]
RECORDING A MASTER PAGE:
[Record]+[Page]
SPLIT SCREENS:
[Tab]+[Down Arrow] (toggles Horizontal & Vertical Split)
[Tab]+[Up Arrow] (single screen)
ADJUST SECTION HEIGHT OF TAB:
[Tab]+{Level Wheel}
ADJUST COLUMN WIDTH:
[Column]+{Level Wheel}
ZOOM CHANNELS:
[Format]+{Level Wheel}
​CHANGE TIME TO %:
[C/Alt]+[Modify]
​CLEAR A MASTER:
[C/Alt]+[Master button]
FETCH (Get Parameters from Another Preset)
1. Be in the preset that you want to update
2. Select the preset # that you want to get parameters from
3. Fetch + Category (Color, Focus, Beam)
Ex. # [Fetch]+[Focus],[Color],[Beam]
ALIGN:
1. Select channel to copy from
2. ADD channels to copy to
3. [Align]+[Focus],[Color],[Beam]
​PROGRAMABLE PARAMETER BUTTON (U1-U2-U3):
1. Select a button ([1] or [2] or [3])
    (Look at the LCD to select which page that you want to record (1/3, 2/3 or 3/3))
2. [Modify]+[Wheel Key] (editor opens)
3. Select parameter you want on each wheel
When you select a channel for a device, pressing 1 or 2 or 3 now has the assigned parameters.
​​ASSIGN MULTIPLE CHANNELS TO A MASTER:
1. Select channels with levels
2. [Preset]+[Master Button] (assigns all the selected channels to the master)
ASSIGN INDIVIDUAL SELECTED CHANNELS TO SEVERAL MASTER:
2. [Channel]+[Master Button]
    (this consecutively assign channels to consecutive masters)
RECORDING A HOME VALUE:
1. Select a fixture
2. Adjust its value for the "home" position
3. [Record]+[Home Attrib]
​HIDING (UNHIDING) the TIME BAR in MAIN PLAYBACK:
[Format]+[Up Arrow]([Down Arrow])
