  • Rigging Power & Control Distribution Options
    PCD-F Faceplate
     208 V. 3 Phase - 8 A. or 15 A. Circuit Breaker
    • an 8 A. breaker is used on P650E/P800G/P1000E/P1300G Powerheads
    • 8 A. breakers will be used until stock has been depleted, then all PCD-Fs will be 15 A.
    • 12 - 3 AWG
    • L15-20 Power Output Connector
    • CPC Data Connector
    PCD-H Faceplate
     480 V. 3 Phase - 16 A. Circuit Breaker
    • L16-20 Power Output Connector
    PCD Raceway
     Can contain both PCD-F and PCD-H faceplates in a single raceway.
    • Two power feed options:
      • Individual/Combined Terminal Feeds
        • 30 A. Max Circuit Feed
        • 22 - 8 AWG
        • Circuits can be in any combination
      • Main Feed
        • Single 3 Phase Feed 170 A. maximum into Power Distribution Block (PDB)
          • Wire termination is done using a 3/16" (incoming power) and 5/64" (individual face plate runs) Allen key.
          • 8 AWG - 2/0
        • Maximum of 12 PCD Face plates per strip standard
        • Possible to customize a strip with a larger PDB for additional face plates.
        • Primary Side Torque Spec (3/16" Allen Key)
          • 2/0 - #14:    120 in. lbs.
          • #8 - #14:     50 in. lbs.
        • Secondary Side (Factory Wiring) Torque Spec (5/64" Allen Key)
          • #10 - #14:   15 in. lbs.
    • Data run is fed into strip via a top hat, the data run can be passed out the opposite end of the raceway via a second top hat.
