  • Obsession 4.4 SMPTE Bug Specifics (SMPTE Skips Every Other Event)
    SCR #1089  A timing error occurs when running SMPTE.
    Expected Results: Should fire each event per the timing allocated in SMPTE.
    Results: When SMPTE show is fired Event 1 thru 5 each fire on time, but event 2 and 4 channels/levels are missed which is reflected in the cue list. Cue's 2 and 4 are skipped which are tied to event 2 and 4.
    Step-by-Step to Reproduce:
    User 1 Live: Chan 1>10 @ FL[enter].
    Live: Record cue 1[enter. User 2 Live: Chan 13 >24 @ 50 [enter].
    Live: Record cue 1[enter].
    Set up the next four cues the same way ,but with different levels.
    Set cues time at 2.2 .
    Go to SMPTE.
    Copy cues 1 thru 5 to event 1 thru 5. increment the timing as follows.
    Event 1  2.2
    Event 2  4.2
    Event 3  6.2
    Event 4  8.2
    Event 5  10.2
    Run SMPTE using internal clock. You can set start time at zero and last time at 14.
    Run SMPTE [S4].
    This bug is fixed in version 4.4.2.
