  • Module Information Summary
    This summary provides module information broken down by market and application. Four major market groups are used to separate modules:
    • UL market - ETC Americas, 120V-60Hz power, Sensor and Unison products
    • CE market - ETC Europe, 230V 50Hz power, Sensor CE and Unison products
    • Hi-voltage (Asian) market - ETC Asia, 240V 50 or 60 Hz power, Sensor "HSR" products
    • Delta (Cruise ship) market - ETC Europe/Americas, Delta (no Neutral) 120/230V 50/60Hz, Sensor and Unison Delta products
    UL Market dimmer modules
    Model #Part NumberModule Description
    Risetime
    Voltage
    L107050A108110A Low Wattage Dimmer
    120V
    L10F7050A108210A Low Wattage 3-Wire Fluorescent Dimmer
    120V
    D157050A1001Dual 1.8kW Dimmer
    350µs
    120V
    D15AF7050A1002Dual 1.8kW Advanced Features (AF) Dimmer
    500µs
    120V
    D15BC
    7050A1010Dual 1.8kW 15A Branch Circuit Breaker
    0s
    120V
    D15CC7050A1011Dual 2.4kW 15A Constant Circuit
    0s
    120V
    D15E7050A1030Dual 1.8kW Enhanced Dimmer
    500µs
    120V
    D15C7050A1060Dual 1.8kW Module Fused (Chicago)
    120V
    D15FB7183A1073EM Fluorescent Constant Module
    120V
    D15F7050A1042Single 1.8kW (3 Wire Fluorescent) Dimmer
    0s
    120V
    D15FC7050A1061Single 1.8kW Fluorescent Module Fused
    120V
    D207050A1003Dual 2.4kW Dimmer
    350µs
    120V
    D20AF7050A1004Dual 2.4kW AF Dimmer
    500µs
    120V
    D20BC7050A1012Dual 2.4kW 20A Branch Circuit Breaker
    0s
    120V
    D20CC7050A1013Dual 2.4kW Constant 20A Circuit
    0s
    120V
    D20DHR7050A1080Dual 2.4kW Dimmer
    800µs
    120V
    D20E7050A1031Dual 2.4kW Enhanced Dimmer
    500µs
    120v
    D20F7050A1006Single 2.4kW (3 wire Fluorescent) Dimmer
    0s
    120V
    D20FB7183A1074EM Fluorescent Constant Module
    D20HR7050A1005Single 2.4kW High Risetime Dimmer
    800µs
    120V
    ELV107183A1017Dual 1.2kW Reverse Phase Module
    120V
    AELV57183A1028Dual 1.4kW Reverse Phase Module
    D50AF7050A1007Single 6kW Dimmer
    500µs
    120V
    D50AFG7050A10716kW Single GFI Module
    500µs
    120V
    D50AFN7050A10706kW Single Neutral Disconnect Module
    500µs
    120V
    D50HR7050A10086kW Single High Risetime Dimmer
    800µs
    120V
    D50CC7050A1022Single 6kW Constant 50A Circuit
    0s
    120V
    D50HR
    7050A1008
    Single 6kW High Risetime Dimmer (2-Slot Module)
    800µs
    120V
    D100AF7050A1009Single 12kW Dimmer (2-Slot Module)
    500µs
    120V
    R15AF7050A1074Dual 1.8kW AF Relay
    0s
    230V
    R20AF7050A1073Dual 2.4kW AF Relay
    0s
    230V
    D20J
    7050A1088Dual 2.5kW
    350µs
    100V
    D20JE7050A1090Dual 2.4kW
    100V
    D20SW7030A1002Dual 2.4kW Sinewave
    100V
    D15AFG7050A1067Dual 1.8kW GFI AF Dimmer
    500µs
    120V
    D15AFN7050A1066Dual 1.8kW Neutral Connect AF Dimmer
    500µs
    120V
    D20AFG7050A1069Dual 2.4kW GFI AF Dimmer
    500µs
    120V
    D20AFN7050A1068Dual 2.4kW Neutral Connect AF Dimmer
    500µs
    120V
    D20AFJ7050A1075Dual 2.4kW 30mA DCS AF Dimmer (Japanese RCD)
    500µs
    100V
    **Not tested at 100,000 AIC, but similar in design to modules which have passed UL 100,000 AIC certification
    High Voltage (H) Market Modules
    All High Voltage modules are installed only in Sensor "H" series racks. These racks are intended for the Asian market area where supply voltage is 230v but CE requirements do not apply.
    Risetime
    Voltage
    HD157050A1045Dual 3kW Dimmer
    225µs
    230V
    HD15AF7050A1046Dual 3kW AF Dimmer
    350µs
    230V
    HD15F7183A1056Single 15A Fluorescent Module
    230V
    HD257050A1047Dual 5kW Dimmer
    225µs
    230V
    HD25AF7050A1043Dual 5kW AF Dimmer
    350µs
    230V
    HD25F7050A1051Single 25A Fluorescent Module
    230V
    HD50AF7050A1048Single 10kW AF Dimmer
    350µs
    230V
    HELV107183A1017Dual 1.2kW Reverse Phase Module
    230V
    HELV57183A1055Dual 5A Reverse Phase Module
     CE Market Modules
    Model #
    Part Number
    Module Description
    Risetime
    Voltage
    ECC15
    7070A1046
    Dual 3kW 15A Constant Circuit
    0s
    230V
    ECC25
    7070A1047
    Dual 5kW 20A Constant Circuit
    0s
    230V
    ED15
    7070A1002
    Dual 3kW Dimmer
    225µs
    230V
    ED15AF
    7070A1003
    Dual 3kW AF Dimmer
    400µs
    230V
    ED15AFN
    7070A1029
    Dual 3.0kW ND AF Dimmer
    400µs
    230V
    ED15AFR
    7070A1030
    Dual 3.0kW Residual Current Disconnect (RCD) AF Dimmer
    400µs
    230V
    ED15AFRF
    7070A1064
    3kW Florescent Dimmer Residual Current Disconnect (RCD)
    400µs
    230V
    ED15AFS
    7070A1004
    Dual 3kW AF Dimmer (Obsolete)
    225µs
    230V
    ED15AFE
    7070A1063
    RED 3kW
    100µs
    230V
    ED15E
    7070A1032
    Dual 5kW Dimmer (Unison)
    400µs
    230V
    ED15N
    7070A1028
    Dual 3.0kW Neutral Disconnect (ND) Dimmer
    225µs
    230V
    ED15NE
    7083A1042
    3kW Neutral Disconnect Dual Module
    400µs
    230V
    ED15RE
    7083A1046
    3kW Residual Current Disconnect (RCD) Dual Module
    400µs
    230V
    ED15RS
    7083A1045
    225µs
    230V
    ED15S
    7070A1035
    Single 5kW Dimmer (Obsolete)
    225µs
    230V
    ED25
    7070A1007
    Dual 5kW Dimmer
    225µs
    230V
    ED25AF
    7070A1003
    Dual 5kW AF Dimmer
    350µs
    230V
    ED25AFN
    7070A1032
    Dual 5.0kW ND AF Dimmer
    350µs
    230V
    ED25AFR
    7070A1033
    Dual 5.0kW RCD ND AF Dimmer
    350µs
    230V
    ED25AFRF
    7070A1065
    5.0kW Fluorescent Dimmable RCD
    350µs
    230V
    ED25AFS
    7070A1009
    Dual 5kW Sense
    250µs
    230V
    ED25AFS
    7070A1004
    Dual 5kW AF Dimmer (Obsolete)
    225µs
    230V
    ED25E
    7070A1034
    Single 5kW Dimmer
    350µs
    230V
    ED25HR
    7070A1027
    Single 5kW AF High Risetime Dimmer
    650µs
    230V
    ED25HRR
    7070A1034
    Single 5.0kW RCD AF High Risetime Dimmer
    650µs
    230V
    ED25N
    7070A1035
    Dual 3.0kW ND Dimmer
    225µs
    230V
    ED25NE
    7083A1044
    5kW Single Dimmer Neutral Disconnect
    600µs
    230V
    ED25NS
    7083A1043
    400µs
    230V
    ED25RE
    7083A1048
    5kW Single Dimmer Residual Current Disconnect (RCD)
    600µs
    230V
    ED25RS
    7083A1047
    400µs
    230V
    ED25S
    7083A1033
    5k Single Dimmer
    400µs
    230V
    ED25S
    7070A1033
    225µs
    230V
    ED50AF
    7070A1013
    350µs
    230V
    ED50AFR
    7070A1035
    Single 10.0kW RCD ND AF Dimmer
    350µs
    230V
    ED50AFS
    7070A1015
    Single 10kW AF Dimmer (Obsolete)
    225µs
    230V
    ER15AF
    7070A1048
    Dual 5kW AF Relay
    0s
    230V
    ER25AF
    7070A1049
    Dual 3kW AF Relay
    0s
    230V
    CDC
    7070A1049
    Dual 3kW AF Relay
    0s
    230V
    Modules with the "S" suffix on the model number are an obsolete Unison module. Information is included for reference only.
