  • Main Processor Error in Expression (1) Consoles
    Error Message
    Main Processor Error Detected
    Cause
    There are several problems that could cause this error.  Memory Corruption (either hardware or software)  usually is at the root of the problem
    Workaround / Fix
    If the corruption is simply software, the corruption can be cleared by performing a diagnostics system clear.  Try this first.  Once the diagnostics system clear is performed, if error comes back, there is most likely a hardware memory failure.  The console will need to be sent to the factory to be repaired.
    NOTE:Your show should first be saved to disk before trying the following:
    To Perform a Diagnostic System Clear:
    1. With Console running, press [SETUP].
    2. Press [6] for System Settings.
    3. Press [Enter].
    4. Press [16].
    5. Press [Enter].
