  • Field Terminations for Unison -ASC
    The field terminations used in Unison are easy to remember and identify.  All low voltage connections are keyed, pluggable, on standard 5mm spacing and made by a variety of manufactures.  To differentiate between the different connections, different sizes are used.  There are 5 different sizes, 3pin (DMX-In), 6pin (DMX-I/O), 8 pin (AUX. Power DC), 10 pin (LinkPower) and 12 pin (0-10V fluorescent).  After wiring a terminal block be sure to replace it in it's matching socket.
    DMX-In
    Type:3 pin 5mm pluggable (male/female)
    Mfg.:Phoenix #1755529 (male)
    Phoenix #1754465 (female)
    Wire Range:
    24 - 12 AWG .2-2.5 mm
    Max. Current4A
    Strip Length:.250"  7mm
    ETC #
    J3273 (female)
    J3277 (male)
    Termination:Located on back of control module.
    Connection:Input from DMX control source (CMEd or CMd)
    Format:Optically isolated RS-485
    Notes:Common tied to Ground via a 10K _ watt resistor
     DMX - I/O
    Type:
    6 pin 5mm pluggable (male/female)
    Mfg.:Phoenix #1755558 (male)
    Phoenix #1754520 (female)
    Wire Range:24 - 12 AWG .2 - 2.5mm
    Max. Current4A
    ETC #
    J3263 (female)
    J3262 (male)
    EAC Signal Distribution PCB 7083B5018
    Connection:Connect to DMX Input /Output CMEd only
    Format:Optically isolated input & output RS-485
    Notes:Both circuits have common tied to Ground via a 10K _ watt resistor (DMXter
    may report errors)
     AUX. Power DC
    Type:8 pin 5mm pluggable (male/female)
    Mfg.:Phoenix #1755574 (male)
    Phoenix #1754562 (female)
    Max. Current:4A
    Strip Length:.250, 7mm
    ETC #
    J3274 (female)
    J3278 (male)
    Voltage:13VDC
    Current:2.5A
    Connection:Connect as supply to LCD Stations
    Station Load:
    6 LCDs
    Note:This connector was formally referred to as the "+12V" connector
    ULP
    Type:
    10 pin 5mm pluggable (male/female)
    Mfg.:Phoenix #1755503 (male)
    Phoenix #1754601 (female)
    Max. Current:4A
    Strip Length:
    .250, 7mm
    ETC #
    J3275 (female)
    J3279 (male)
    DR12/6 Architectural option 7083B5011
    Voltage:42 VAC
    Current:
    1 A
    Connection:Connect to Stations
    Station Load:
    32 Stations
    Electronic Fluorescent 0-10V
    Type:
    12 pin 5mm pluggable (male/female)
    Mfg.:Phoenix #1755600 (male)
    Phoenix #1754643 (female)
    Max. Current:4A
    Strip Length:
    .250, 7mm
    ETC #J3276 (female)
    J3280 (male)
    One of 4 connectors where n is circuit number
    Connector 1(Upper left)  #1-6
    Connector 2(Upper right) # 6-12
    Connector 3(Lower left) # 13-18
    Connector 4(Lower right) # 19-24
    Format:Current Sink, use with 0-10V only
     DR12 Phase Feed Lugs, 3P
    Type:Single conductor lug
    Mfg.:ILSCO TA-250
    ETC#J371
    Wire Range:250MCM - 6 AWG
    Strip Length:1.125"
    Hex Size:
    5/16
    (1)  Neutral bar DR12 3P
    Connection:Connect to incoming power feed
    DR12 Phase Feed Lugs, 1P
    Type:Dual conductor lug
    Mfg.:ILSCO AU-250
    ETC#J3200
    Strip Length:
    1.125 "
    Hex Size:
    5/16
    (2) Left Side phase bars DR12 1P
    (1)  Neutral bar DR12 1P
    DR 6 Phase Feed Lugs
    Mfg.:
    ILSCO TA-2/0
    ETC#J311
    Wire Range:2/0 - 6 AWG
    Strip Length:
    .750"
    Hex Size:
    3/16
    (2) Left Side phase bars, DR6 1P
    (1)  Neutral bar, DR6
    Connection:
    DR6/12 Ground/Neutral Load Terminations
    Type:Terminal Strip
    Mfg.:
    ILSCO 167-12
    ETC#J3181
    Wire Range:4 - 14 AWG (12 Terminations)
    (1)  Back Wall DR6
    (2)  Neutral Bar
    Connection:Connect Load Neutral/Ground
    DR6/12 Load Terminations
    Type:Load Terminal
    Mfg.:ILSCO CO4CW
    ETC#J3180
    Wire Range:14 - 8 AWG
    Bypass Option Connectors
    Type:2 and 4 pin .100 Molex headers
    Connection:Internal wiring harness supplied with Bypass Option Kit
    ETC#
    7083B7013, 7083B7014
    Remote Sense Phase Connection
    Type:2 pin female terminal block
    Mfg.:Phoenix 1706785
    Wire Range:14 - 6 AWG
    Connection:Connect to remote 'normal power' source
    ETC#J3266
    Internal Sense Phase Connection
    Connection:
    Connect via cable assembly 7083B7017 internally
    refer to installation instructions for more information.
    ETC#
    J3266
