  • Expression 2/3 Line Remote Macros
    The Expression 2.3 Line consoles provide eight remote macro inputs through the 25-pin connector on the back panel labeled Remote Go. A user-supplied remote device connects to the console via a 24 AWG, aluminum-shielded, multi-conductor cable with one twisted pair designated for each switch (Belden 9507 S-R PCV Insulated or Alpha 5477 80 Deg. C 300 V PVC). The cable connector at the remote device will vary depending on the device itself.
    Console connector  Remote connector
    DB-25 female   Connector type depends on unit
    Pin  Function
    1  -Macro 1,901
    2  -Macro 1,902
    3  -Macro 1,903
    4  -Macro 1,904
    5  -Macro 1,905
    6  -Macro 1,906
    7  -Macro 1,907
    8  -Macro 1,908
    9  N/C
    10  Ground
    11  + 12Vdc
    12  N/C
    13  N/C
    14  +Macro 1,901
    15  +Macro 1,902
    16  +Macro 1,903
    17  +Macro 1,904
    18  +Macro 1,905
    19  +Macro 1,906
    20  +Macro 1,907
    21  +Macro 1,908
    22  N/C
    23  Ground
    24  + 12Vdc
    25  N/C
    The Three Ways to Wire
    (#1 is most typical way of wiring.  Remote Macro also requires ribbon cable and chips in Facepanel PCB.)1)
    Connect all -Macro pins (pins 1-8) to ground (pin 10) and switch the leads connecting the +Macro pins (pins 14-21) to +12 Vdc (pin 24).2)
    Connect all +Macro pins (pins 14-21) to the +12 Vdc pin (pin 24) and switch the leads connecting the -Macro pins (pins 1-8) to the ground (pin 10).3)
    Provide your own power supply that generates a 12 Vdc potential between the +Macro and -Macro pins and switch either of these leads.
