  • ETCNet2 Two Port DMX Node Information
             Two Port Wallmount Node                                                     Two Port Touring Node
    Two Port DMX                             Two Port Touring
    The ETCNet2 Two Port Node was available as either a wallmount (backbox mounting) version or as a touring version with either two male or two female 5-pin XLR connectors. Similarly to other Net2 products the connectors can be inputs or outputs irrespective of their gender.
    The node took either a 24V DC input on a two pin header (wallmount) or DC barrel connector (touring), or could in both cases be powered by Power-over-Ethernet.
    The Two Port Node was obsoleted by the introduction of the Net3 2 Port Gateway in 2008.
