• Enabling 16-bit fade control
    Enabling 16-Bit Fade Control
    •  Push the setup button []
    • Scroll down to [Rack] and push [Enter]
    • Scroll down to DMX       A: and make sure it is [Enabled].
    • Under DMX      A: you will see 16 Bit Mode:              [No].
    • To change the mode make sure it is highlighted and then push [Enter].
    • Either choose [Yes] or [No].
    A very fine control or smooth fade concept which moving lights use for their control. Controls the intensity of the lights. If you change the 16-bit mode it requires repatching of all the lights. The console also will require some reprogramming as well.
