  • Emphasis: Setting or Changing System Manager Password
    Setting Password for System Manager
    • Login as System Manager
    • Go to Start Button
    • Select All Programs
    • Select User Accounts
    • Click Create a Password
    • Type in password in appropriate spaces
    • Type hint. This hint will appear when you press the question mark by the login.
    • Click Create Password
    This password will be required the next time you login as system manager.
    Removing System Manager Password: If known
    • Log in as system manager with password
    • Go to Start
    • Click Remove my password
    • Type password in the box
    • Click Remove Password
    If you don't know what the password is, a technician can remove it using the Technical Service log in.
    Alternately, you need to reload the disk image in order to remove the password.
