  • Emphasis: Globally Change the Report Headers in Visualization
    If the file is created in R8:
    Go to any report
    Go to Redesign Headings
    Make the changes that you need
    Save the File
    Select Yes to save globally
    If the file is created in a version earlier than R8:
    Go to any report
    Change the Title of the report to be %title%
    Make your other necessary changes
    Save the File
    Select Yes to save Globally
    By changing the report title to be %title%, it will retain the title of the shortcut that you select, but all other elements will be changed to their new values.
