  • What is the Curve on a CE (European) Sensor Module Breaker?
    • Prior to 1998 all breakers were D curve.
    • Since 1998 all single pole breakers have been changed to C curve.
    • From 1998 to 2009 all double pole breakers were still D curve.
    • Since 2009, all CE breakers (Single Pole, ND, RCD) have been C curve.
    • C & D Curves are defined by a European Standard. A is the fastest curve, D is the slowest.
    Note:
    The curve letter describes the trip time/current for overcurrent tripping.  It is an important parameter for installers.
