• Congo Version 4.x C++ Memory Error
    Occasionally a Congo Console will not login to Server.  You will get a Windows Visual C++ error or a Memory Exception error referencing a memory location.  The application will not start if this error is presented.  This error is caused because the Congo application that is attempting to load a corrupt backup file (recovery.asc or saved.asc.)  These files can be removed from the Congo Hard Drive to prevent this error from popping up.
    See the attached PDF for Step-by-Step instructions for resolving this problem.
    Attachment: Congo C++ Memory Error
