  • Composer Lite and Programming Jacks
    Question:
    Can I use an Irideon Programming Jack to send composer lite configs into my Irideon Fixtures?
    Answer:
    YES!  As long as the programming jack is only attached to the fixtures and not to an MCP you would be able to send Composer Lite Sequences to the units.  If the system contains an MCP you will not be able to transfer Composer lite configs through it.
