Sortieren nach:- By Product
Die Selador-Serie von ETCArchitektur-Lichtsteuersystem - By Document Type
- Alle sehen
 Suggested placement of Selador Series LED fixtures to wash cycs  Adding & configuring sensors in LightDesigner  Typcial wired, wireless, and docking station systems  By Steve Terry (2010), Discussion of UL924, UL1008, and other Codes pertaining to Emergency Lighting Control  The safe use of Selador LED luminaires to illuminate works of art, objects in a museum or similar delicate photosensitive objects requires knowledge of the ultraviolet radiation emitted.  This Application Note identifies as well as describes the various control functions of Paradigm  Mike Wood discusses the problems with defining "White' in regards to LED based light.  Mike Wood takes a look at the fundamental functions of an LED.  Mike Wood discusses the quality of light from LEDs.  A quick how-to about setting minimum light levels  An explanation of entertainment lighting control philosophy by Anne Valentino and Sarah Clausen, ETC Control Product Managers.  Incorporating Hubbell Building Automation sensors in Unison systems  To assist you with system design, understanding, use and specification of ETC distribution equipment.  Included in this document are typical Unison ERn enclosure worst case BTU outputs  David North walks you through the process of identifying the correct dimmer system for your installations.  Application Note about the new D20FB modules  Application Note about software and firmware updates to Unison Paradigm components  Understanding Common-Neutral (Multi-wire) Branch Circuits
and Phase-Control Dimming Installations. Updated for 2008 NEC code  Application Note about design themes in Control Designer  David North discusses what to consider when selecting a fixture.  Power Feed considerations for Distributed Dimming systems  NEC Acceptability of ETC UL Listed Dimmers and Associated Branch Circuits Operated at 100% Load, 100% Continuous Rating. By Steve Terry, written specifically for Engineers and AHJs  Unique Global Dimmer Load Survey Delivers Surprising Results  By Steve Terry (2005), Different Meanings and Applications for AIC and SCCR  By Ellen White (2005), Brief on the two Nationally Recognized Test Laboratories  Understanding Wire Temperature Ratings, Dimmer Racks, and Conduit Fill. By Steve Terry (2005), Key Points to Help Explain Wire Temperature Ratings  by David North (2004), Choosing between Dimmer and Relay Modules  By Steve Terry (2004), A successful GFCI Dimmer installation relies on a number of factors that must be planned well in advance.  By David North (2001), Simple explanation of rise-time  Accoustic Tests for ETC Dimmer Racks by Soundcoat in Irvine, CA  The key to achieving both beautiful and functional results  Entscheidende Voraussetzungen für schöne und gleichzeitig funktionale Ergebnisse
