Hey I'm using a Express 24/48 and whenever i try and control dimmers the lights won't go on off. and stuff. however the channels work great!
is there something wrong with a patch or something?
I'm thinking it's going to be something really obious that i just got past me.. help ?
Hi there -
Do you mean when you try to bring up dimmers directly from the keypad? Like [Dimmer] [1] [Full]? If so, you have to press [ENTER] after [Full], then you will be in dimmer check mode and you can then use + and - to move from dimmer to dimmer.
Does that help?
Thanks-
Sarah
