Electronic Theatre Controls
Welcome to the online community at ETC
Welcome to Electronic Theatre Controls Sign in | Join | Help
in Search
KVM switching.
Last post 09-05-2008, 12:54 PM by NAC JIM. 8 replies.
Sort Posts: Previous Next
  •  07-01-2008, 5:23 AM 7689
    KVM switching.
    We have a Congo Senior and a Congo Junior connected as a server and backup pair in our live studio environment - as recommended by ETC. This generally works ok.
    However, when we switch between the 2 desks we need to switch our single keyboard and mouse between them - this is performed via a KVM switcher. We find, more often than not, that the KVM switcher 'locks up' and loses all functionality when we switch between the 2 desks. Only a power down/reset of the KVM switcher restores normal operation. We understand that the Senior uses USB 2.0, and that the Junior uses USB 1.1.
    We wonder if this is the cause of our problem - that the KVM switcher is not 'happy' with sourcing signals to two different USB spec devices.
    Has anyone else experienced these problems - we have tried two diffrent KVM switches and the result is the same - locks up.
  •  07-01-2008, 9:10 AM 7692 in reply to 7689
    Re: KVM switching.
    Have you tried using the PS2 Connection and switching that, instead of USB?
    Best of luck,
    Jay
  •  07-02-2008, 4:19 AM 7723 in reply to 7692
    Re: KVM switching.
    Thanks for the suggestion Jay, whilst the Junior does have PS2 connections on the rear panel the Senior does not - it has USB only.
    I suppose this does beg the question " ... does the motherboard inside the Senior have PS2 connections that could be brought out to the rear of the panel somehow ..?" I guess I will have to go and have a look inside the Senior desk when it is free.
    I was also rather hoping for a reply from ETC to my question....
  •  07-02-2008, 5:30 AM 7727 in reply to 7723
    Re: KVM switching.
    USB KVM switchers are a bit of a mixed bunch.
    Some of them are quite clever and act as a real 'host' to the USB keyboard & mouse, and present themselves to the host PC as real mice/keyboards even when switched the 'other way'.
    Some of them are just 'dumb switches', and simply contain a series of (hopefully) USB-spec switches to re-route the data to/from the relevant unit. (Think video crash-box)
    I'm not entirely sure which variety is better.
    The 'smart' KVM will switch faster, but runs the risk of misidentifying itself or the connected devices, while the 'dumb' KVM requires the host to re-identify the connected devices, and if it doesn't turn the connected devices off for long enough they may not attempt to re-connect.
    USB 2.0 adds an additional layer of complexity to this, as at the first attempt to connect it will try to use the full-speed USB 2.0, then again in High-Speed mode, and finally in USB 1.1 mode.
    As to the question of PS/2 - the ports do physically exist on a Congo Senior, but you can't access them as the CPU metalwork hides them.
    PS/2 KVMs are generally better as PS/2 isn't officially hot-pluggable, so all decent PS/2 KVMs host the keyboard & mouse themselves and pretend to be a single unit to the host.
    Unfortunately there does appear to be something strange with the KVM unit itself, so you'll need to contact that manufacturer.
    As a temporary workaround, you could simply use separate keyboards and mouses for the two consoles, only sharing the monitors themselves.
    If you can live with the slower USB pen drive access, it is possible to slow a Congo Senior down to USB 1.1 - however they've not been extensively tested in that configuration.
    Keep on trying till you run out of cake.
  •  07-03-2008, 3:11 AM 7745 in reply to 7727
    Re: KVM switching.
    Hi Richard,
    Thanks for the information. We have been in touch with the American manufacturer of our KVM switches since we thought we may have a faulty unit - however we have tried 3 identical units now and each one gives unsatisfacory results so I think it is a case of we have innocently bought unsuitable units.
    With reference to your comment:
    Could you recommend such a kvm switcher that we could try?
  •  07-03-2008, 4:16 AM 7746 in reply to 7745
    Re: KVM switching.
    Unfortunately I've not had the chance to try out any USB KVMs on a Congo Jr/Senior pairing, so I'm hesitant to recommend any particular devices at present - I've only used PS/2 KVMs on Congo Lightservers and Jrs.
    I think Erik Larsen has tried some out USB ones - I'll point him at this thread and ask if he has any ideas.
  •  07-03-2008, 8:10 AM 7749 in reply to 7746
    Re: KVM switching.
    Thank you Richard - we look forward to your colleagues ideas and suggestions.
  •  07-19-2008, 7:52 AM 8013 in reply to 7749
    Re: KVM switching.
    Hi Richard,
     Have you been able to get any feedback on this from your colleagues?
  •  09-05-2008, 12:54 PM 8679 in reply to 8013
    Re: KVM switching.
    I am using a IOGear KVM switch between my congo and Lightserver and have had no issue.   The model # is : GCS632U. Have not tried any other make or model. Guess we got lucky on the first try.
View as RSS news feed in XML
Powered by Community Server (Commercial Edition), by Telligent Systems
