Electronic Theatre Controls
Welcome to the online community at ETC
Welcome to Electronic Theatre Controls Sign in | Join | Help
in Search
A few simple Ion macros
Last post 07-02-2008, 8:18 AM by Anne Valentino. 3 replies.
Sort Posts: Previous Next
  •  06-30-2008, 8:17 PM 7684
    Hey guys,
    I am trying to write a few simple macros, but Ion macros appear to be a bit more complex than on the earlier ETC consoles.
    I would like to write LAMP ON and LAMP OFF macros for my moving lights.  Right now, LAMP ON macro looks like this:
    Group 1 (All ML's) ENTER LAMP_ON ENTER
    I came by this macro by learning the sequence, then deleting all of the seemingly unnecessary "Lamp Ctrls," "Select_Last," and "Reset_Cmd" commands. This macro works fine.
    However, my LAMP OFF macro reads:
    Group 1 (All ML's) ENTER LAMP_OFF ENTER
    When I fire this macro, my command line only reads "Group 1 Enter".  For some reason, it is not taking the "LAMP_OFF" command.  Why is this?
    Also, is there a way I can make a Console Shutdown macro that does the following things:
    1.) Lamp off All ML's
    2.) Save to Show Archive
    3.) Power off console
    4.) Leave the CIA on the "Confirm" screen so that you have to confirm before powering off
    It appears that the "Power off console" command in the browser does not get recorded into the macro the same way that the Save command does.  Or perhaps those Browser commands don't get stored in the macro without their confirm commands...?
    Any help would be appreciated!
    Ethan
    ethan@E-Lumination.net
    Ion V1.4.1
    Ethan Kaplan
    Ion v1.4.1
    Filed under:
  •  07-01-2008, 12:05 PM 7702 in reply to 7684
    Re: A few simple Ion macros
    Hi Ethan.  I tried these macros and they seem to work fine.  I opened About and then Lamp Controls.
    [Learn] [Macro] [1] [Enter] [Channel Select] [Lamp On] [Enter] [Learn]
    [Learn] [Macro] [2] [Enter] [Channel Select] [Lamp Off] [Enter] [Learn]
     Can you give that sequence a try.  When you looked at the macros in the macro editor, they looked correct?  In general terms, since Select Last is a context sensitive instruction, its probably best to avoid it in macros.
    Right now, there are a handful of CIA instructions that can't be included in Macros.  Power Off is one of them.
    Hope this helps.
    a
    Anne Valentino
    Eos Product Line Manager
  •  07-01-2008, 7:24 PM 7715 in reply to 7702
    Thanks Anne.
    It seems that the console automatically includes Select Last commands while I am learning the macro.  I am not using the key during the learn sequence.
    When I use your keystrokes exactly, then view the macro in the Macro List, this is what the macro reads:
    Group 1 _RESET_COMMAND Select_Last Lamp_Control Lamp_On ENTER
    Why does it need to add all of that extra gak?
    Ethan Kaplan
    Ion v1.4.1
  •  07-02-2008, 8:18 AM 7730 in reply to 7715
    Long story, but this macro combination on Ion will be fixed in 1.4.2 (which is due out the first week of August).
    Thanks much!
    Anne Valentino
View as RSS news feed in XML
Powered by Community Server (Commercial Edition), by Telligent Systems
