Electronic Theatre Controls
Welcome to the online community at ETC
Welcome to Electronic Theatre Controls Sign in | Join | Help
in Search
Bug - Congo with Net3 Remote
Last post 07-08-2008, 4:14 PM by Phil M. 9 replies.
Sort Posts: Previous Next
  •  06-27-2008, 1:37 PM 7640
    Attachment: Bugged.asc
    Information
    Version: 5.0.0.9.0.42
    Console Firmware:  1.0.0.0.0.009
    IO Firmware:  1.2.0.9.0.1
    Channels:  3072
    Outputs:  2048
    My Scenario:  I have the play up and running.  The console is in LIVE mode.  I am up in the cats.  I begin a channel/output (so I know what ouputs are in said channel) check.  I proceed to use the Net3 RFR and go into the Patch portion of the 'controls.'  I type in Channel 10 and see that nothing is patched into that channel.  I then use the left 'scroll' wheel on the left side of the remote and scroll into channel 11.  I then may scroll back to channel 9 (if I am lucky - see what follows).  The remote seems to have locked up.  No response from the keys, etc.  I turn the remote off - wait a few - turn it back on - the remote does not connect.  I climb down from the cats and see that the console is 'locked-up,' 'frozen,' 'messed-up' etc.  On the 3 monitors is the gray slate background with CONGO across them...no response from the console.  I reboot the board.  I repeat the above scenario and have the same results.  I have done this 4 times now.
    Attached is my show file labeled Bugged. All y'all feel free to give it a shot (not that you have the time) - but curious to hear your results.
    -Dana
    Filed under: , , ,
  •  06-27-2008, 1:48 PM 7642 in reply to 7640
    Re: Bug - Congo with Net3 Remote
    Hi Dana -
    I have forwarded this information to R&D for further investigation.
    In the mean time, I would suggest not using those commands from the RFR.
    Thanks for the detailed report!
    Sarah
    Sarah Clausen
    Controls Product Manager
    ETC, Inc.
  •  06-30-2008, 11:02 AM 7679 in reply to 7640
    whoa, that chrashes pretty quickly.  Have you had any bug after you restart?
     Alex
  •  06-30-2008, 12:03 PM 7680 in reply to 7679
    Alex -
    Yes.  I restart and go through the same commands and the same end result happens.  I am not a computer programmer, but I would label it as a bug.  So, thanks to Sarah for forwarding it along to R&D and we will see what happens.
    Now, if you mean any other sort of bugs not directly relating to this issue - no I have not.
    Thanks for you concern.
    -Dana
  •  07-02-2008, 9:04 AM 7731 in reply to 7680
    Hi Dana
    Thanks for such specific information, we were able to track this down and it will be fixed in the next patch.
    Alex
  •  07-04-2008, 7:03 AM 7756 in reply to 7731
    Hi
    while on the subject of the remote I have a couple of questions
    1 when the congo is in AT mode is it possible for the remote to work the same way eg 1 thru 10 @100
    2 I love the funcion of scrolling through the group names on the remote but when you scroll to the desired group why is this not selected rather than having to exit the menu and input #GROUP
    Phil
    Phil Marjoram
    Motherwell Concert Hall & Theatre
  •  07-04-2008, 1:38 PM 7766 in reply to 7756
    In Congo v5 the remotes (RFR, CRRFU and phone remote) use the same syntax as the console. This is a change from v4.3.4
    Keep on trying till you run out of cake.
  •  07-07-2008, 9:33 AM 7789 in reply to 7756
    Hello -
    With regard to point #2, I believe you should be able to scroll to the selected group and then press the encoder wheel "in" to engage the switch and select that group. You should not have to remember the group number and then enter it manually...
    Sarah
    Sarah Clausen
    ETC, Inc.
  •  07-08-2008, 8:20 AM 7799 in reply to 7789
    Sarah and Others -
    That is correct.  You certainly can use the encoder wheel to select groups as Sarah has indicated.  Additionally, thank you Alex for the update on the bug and will look forward to the updated patch.
    -Dana
  •  07-08-2008, 4:14 PM 7813 in reply to 7799
    Thanks guys that is really great
    Thanks for your answers
    Phil
    Phil Marjoram
View as RSS news feed in XML
Powered by Community Server (Commercial Edition), by Telligent Systems
